ABS failure?
Old Oct 31, 2007 | 02:58 PM
rupert's Avatar
Default ABS failure?
My '98 A-6 quattro has begun to show the ABS failure (solid yellow) and the blinking red Brakes after driving for a while. I read the posts on this andam prepared to remove the EBTCM and send to ModuleMaster. One last question before I do this. This is an intermittent problem.The ABS and Brake warning lights come on after driving a while. Sometimes they go back out on their own and that's it for the drive. Othertimes they later come back on. It always clears if I turn the car off for a while. Is this the same issue?
Thanks
Old Nov 2, 2007 | 10:54 AM
rmknox's Avatar
Default RE: ABS failure?
Rupert,
Those are the same symptoms I had before I removed my module and sent it off to Module Masters. It was intermittent at first but gradually became more of a constant problem. Although they say you can, I did not drive my car without the module mainly because I wanted to take it apart only once and put it back together once. To drive it you would need to do both twice. I shipped mine Monday, Fedex 2 day delivery and had Module Mastersship it back Fedex overnite and received it the following Monday, one week to the day. Have fun, be careful and take your time.
TimBirkin
Sep 4, 2014 09:27 AM
Kabendawggg
Jan 14, 2013 02:51 PM
mannelito
B7 Models
Jun 12, 2008 01:44 PM
sublime82
Oct 16, 2006 11:16 AM
