ABS Problem?
Old Apr 24, 2006 | 01:48 PM
skyman8's Avatar
Default ABS Problem?
Hi, I have a problem on my Audi A6 1998. The ABS light will come on first then the Oil pressure symbol (oil drip can), then the autobox goes into safe mode (top gear?) and the rev counter stops working.
Any idea please of what is the cause?
Regards
Peter
Old Apr 25, 2006 | 05:33 PM
dankhound's Avatar
Default RE: ABS Problem?
You have a failure somewhere on the databus. Try unplugging the abs control module and see if that fixes it. If it does, you need a new abs control module.
Old Apr 25, 2006 | 06:17 PM
skyman8's Avatar
Thanks, Audi had confirm that it's the ABS Module and so have a independent ABS specialist.
Regards
Peter
Old Apr 27, 2006 | 11:27 PM
mpw2.7T's Avatar
Default If it's the ABS module, try...
www.ModuleMaster.com. Removing the module is pretty easy. You send it off and <$300 and a few days later, you can re-install.
Do a search on AudiWorld for ABS - loads of good info.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
