AC climate control
Old Jul 2, 2014 | 02:22 PM
AnthonySlaughter's Avatar
Default AC climate control
2002 Audi A6. 3.0 , I had a issue with my economy button staying on. I swap a climate control module and now my ac is blowing hot. Also I notice my engine temp sensor is bad my engine temp sometimes comes up or stay on cold. Compressor is turning. Is there any progaming when swapping modules? And do I need to address the engine temp also in order to fix my AC?
Old Aug 3, 2014 | 07:27 PM
Previous module was good. AC buttons will stay on if there is a problem with the AC. It turns out to be a high pressure switch was bad. And then I replace the eng coolant temp sensor . I had the system recharged and dye put in to see if there is a leak.
markvc1
May 25, 2009 01:07 PM
a8audiv8
Apr 13, 2007 05:33 PM
cian_ie
Jan 10, 2007 07:07 PM
02A4
Mar 27, 2005 10:42 AM
