Ac help anyone
Well you don't need the dealer but you do need a set of manifold gauges and a vag com to check the faults in the a/c control head. If you can't get a hold of manifold gauges (not legal for civilians to have in all states) then just give us the fault codes. If there are no fault codes you would need to go to at least an A/C certified repair shop so they can monitor the pressures on both the high and low side.
You can only see the low side, which doesn't tell me crap.
Thank you sir.
I'm not getting any codes (that I'm aware of). And I should tell you when I put the can on it goes to 140. Full is supposed to be around 45 according to the can.
Yes, I am way over my head here.
Can it be reading that high because there is no refrigerant and compressor is not kicking on?
Okay...have discovered that is the problem. If the compressor is not coming on, gauge will read very high. Without the compressor running it can't take a charge.
So next step.....where is the low pressure switch located in my car, can someone point me to it. Seems I can short #1 and #2 to get the compressor running and then try to charge.
If you aren't too familiar with A/C systems you should really leave it up to a professional. There are several possible problems. Low refrigerant, bad low pressure switch, bad high pressure switch, plugged expansion valve/orifice tube, faulty climate control unit, bad compressor, faulty relays.....
Messing around and jumping the compressor is not for someone who doesn't at the least have a set of manifold gauges hooked up.
Thanks Jeff. And you are correct. That is usually my advice also.
But I'm willing to learn. I wouldn't be comfortable bringing it anywhere but Audi but don't want to keep doing that. I think they start billing me the minute I get them on the phone.
I'm an Engineer, my boss is also, he has the gauges and his Dad had his own AC business his entire life. So I'm not completely unarmed.
I could probably check all of that if I knew where it was.
Having said that....lo and behold on the way home yesterday the dam AC just CAME ON. Pulled in my driveway and quickly stuck the can on it. Doesn't need refrigerant. It's right where it's supposed to be.
So now I got to wait and see if it stops working again. At least thats one thing off the list. It's not refrigerant.
