Ac help anyone
Old Apr 29, 2009 | 03:45 PM
Kelly-4.2's Avatar
Default Ac help anyone
No cold air.
Checked refrigerant (by gauge on refill can), checked fuses. I hear the compressor come on once, shuts off and won't come on again.
Econ button off.
Please don't say dealer
Old Apr 29, 2009 | 07:03 PM
auditech79's Avatar
Well you don't need the dealer but you do need a set of manifold gauges and a vag com to check the faults in the a/c control head. If you can't get a hold of manifold gauges (not legal for civilians to have in all states) then just give us the fault codes. If there are no fault codes you would need to go to at least an A/C certified repair shop so they can monitor the pressures on both the high and low side.
You can only see the low side, which doesn't tell me crap.
Old Apr 30, 2009 | 08:55 AM
Kelly-4.2's Avatar
Thank you sir.
I'm not getting any codes (that I'm aware of). And I should tell you when I put the can on it goes to 140. Full is supposed to be around 45 according to the can.
Yes, I am way over my head here.
Can it be reading that high because there is no refrigerant and compressor is not kicking on?
Old Apr 30, 2009 | 04:18 PM
Kelly-4.2's Avatar
Okay...have discovered that is the problem. If the compressor is not coming on, gauge will read very high. Without the compressor running it can't take a charge.
So next step.....where is the low pressure switch located in my car, can someone point me to it. Seems I can short #1 and #2 to get the compressor running and then try to charge.
Old May 1, 2009 | 12:43 AM
Jeffla's Avatar
If you aren't too familiar with A/C systems you should really leave it up to a professional. There are several possible problems. Low refrigerant, bad low pressure switch, bad high pressure switch, plugged expansion valve/orifice tube, faulty climate control unit, bad compressor, faulty relays.....
Messing around and jumping the compressor is not for someone who doesn't at the least have a set of manifold gauges hooked up.
Old May 1, 2009 | 06:49 AM
Kelly-4.2's Avatar
Thanks Jeff. And you are correct. That is usually my advice also.
But I'm willing to learn. I wouldn't be comfortable bringing it anywhere but Audi but don't want to keep doing that. I think they start billing me the minute I get them on the phone.
I'm an Engineer, my boss is also, he has the gauges and his Dad had his own AC business his entire life. So I'm not completely unarmed.
I could probably check all of that if I knew where it was.
Having said that....lo and behold on the way home yesterday the dam AC just CAME ON. Pulled in my driveway and quickly stuck the can on it. Doesn't need refrigerant. It's right where it's supposed to be.
So now I got to wait and see if it stops working again. At least thats one thing off the list. It's not refrigerant.
Old May 1, 2009 | 06:55 AM
Kevin's Avatar
Its a known problem, take a look at TSB 2020124/1. If you don't have access to the TSB, drop me a PM with your e-mail adress and refernce the AC being inoperative and I will send you the TSB.
Old May 1, 2009 | 08:31 AM
Kelly-4.2's Avatar
Thank you kindly sir. PM sent.
Worked this morning also.
Old May 1, 2009 | 02:17 PM
zelembac's Avatar
Thumbs up ac diagnostic
hi there
take look at this link maybe will help you http://www.audiworld.com/tech/
good luck
Old May 1, 2009 | 05:32 PM
Kevin's Avatar
TSBs have been sent.
