Acetone used as a fuel additive
Old Oct 7, 2010 | 10:57 PM
jhuffman's Avatar
happen to have the names of those additives uber? I'm trying to track down popular additives for comparison
Old Oct 8, 2010 | 04:28 PM
Theiceman's Avatar
i use techron on my older 911 and have no complaints ..
Old Oct 8, 2010 | 04:38 PM
jhuffman's Avatar
the local checker has a buy 1 get one free on techron... might have to take advantage of that.
Old Oct 9, 2010 | 01:32 PM
UberTeile's Avatar
Sure.....
ZVW239003 - "Gasoline Additive" 192ml bottle - msrp $4.25
This is the factory recommended maintanence dose that's been around for years. I use this stuff at least once a month.
G001770A2 - "Multipurpose Additive for Petrol" 90ml can w/spout - msrp $8.00
This is the intensive cleaner recommended for the alleviation of fuel quaility issues on newer FSI engines, but it can be used in non-FSI cars as well.
UberTeile
Old Oct 9, 2010 | 10:30 PM
jhuffman's Avatar
thanks, I'll check those out. I take it from your continued use that its good stuff? How does it compare to 44K?
Old Oct 11, 2010 | 08:23 AM
UberTeile's Avatar
I've never used BG 44K in a VW or Audi, nor have I ever seen any side-by-side comparisons...but the "Gasoline Additive" is probably more comparible to Chevron Techron in that it significantly reduces deposit accumulation. I've also used it repeatedly in my 300k+ mile Volvo and the tops of intake valves were always sparkly clean.
Old Oct 12, 2010 | 02:50 PM
nemohm's Avatar
The main attribute of acetone is the ability to dramatically reduce the surfice tention of the gasoline - the result should be better vaporization and completeness of the fuel-air mixing->enhancing the burning efficiency.
As many sourses point - not all acetone is created equal - the best should be some brand used in Beauty salons.
I periodically run acetyone (as only additive) in my cars - no adverse effect, neither any benefits.
I tend to assume I have not found the correct acetone yet...
My home blend (based on the ingredients found in LubroMoly, WD40 and Seafoam) is:
kerosene -30%
naphtha -30%
mineral spirits -30%
toluene-xylene-acetone -10%
Old Oct 13, 2010 | 12:31 AM
  #18
jhuffman's Avatar
Thats the best explanation I've heard for using acetone. You mix up a home blend, how interesting. What other spirits have a surface tension reducing property?
Old Oct 17, 2010 | 01:49 PM
  #19
tron49's Avatar
Originally Posted by UberTeile
Sure.....
UberTeile
Where can I purchase the G001770A2.... At the Audi dealership they want $18 a can, thats ridiculous. Any help would be greatly appreciated.
Thanks
Sigmund Cieszkiewicz
Old Oct 17, 2010 | 08:18 PM
  #20
UberTeile's Avatar
Ridiculous, indeed...
Here ya' go, ECS has it...http://www.ecstuning.com/Search_VW/G00170003/ES1895145/
UberTeile
