Air bag light
Old Aug 25, 2006 | 01:05 PM
midgeschmidt's Avatar
Default Air bag light
My 1999 Audi A6 just had the fuel pump replaced. When I picked the car up at the shop, the airbag light is now on. Could the light being on be caused by what the mechanic did to replace the fuel pump or is this just a coincidence and the airbag light is a separate problem? Thanks!
Old Aug 25, 2006 | 03:57 PM
Boston Driver's Avatar
Default RE: Air bag light
Find a VAG COM and get the error code for the airbag light. It will tell you why the code is being thrown. Maybe your local AutoZone can do it for you.
Old Aug 30, 2006 | 05:50 PM
teddybgame's Avatar
ORIGINAL: midgeschmidt
It is possible that they disconnected something. The rear seats have an airbag senor...but I doubt the mechanic had to pull out the rear seat bottom to get to the fuel pump.
I would find somebody with a VAGCOM that can check the code. Maybe it can be cleared. Go to audiworld.com and post on the VAGCOM forum.
-Ted
Old Aug 30, 2006 | 05:54 PM
techbod's Avatar
did the mechanic disconnect the battery?? and did he do it the right way??, remove the ground wire only for approx 20 seconds or longer this resets the SRS light
Old Sep 3, 2006 | 02:57 PM
dankhound's Avatar
If you have rear side airbags there is indeed a connector under the rear seat which must be disconnected to replace the pump. I would pull the rear seat out and check that.
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
