Air Con/ Climate control problem
Old Jun 30, 2006 | 06:49 PM
JG's Avatar
JG
Default Air Con/ Climate control problem
The AC is only blowing hot air. The compressor is not switching in normal operation, neither does it engage when you hit the compressor switch on the control panel. It however will engage and operate on a separate live feed.
Had the system regassed but no change in compressor behaviour although blowing slightly cooler.
The regassing took longer than usual (apparently) the AC gassing guy thought that there might be a blockage in the system
Any ideas?
Old Jun 30, 2006 | 09:42 PM
audiSean's Avatar
Default RE: Air Con/ Climate control problem
Have you run the climate control diagnostics on the head unit? Any errors there? If you're not sure how to run the diagnostics, this this link:
http://www.audiworld.com/tech/int5.shtml
Old Jul 1, 2006 | 07:51 AM
JG's Avatar
JG
Thanks for ths suggestion. I will give it a try.
bjlong
Nov 17, 2010 10:42 PM
EZAVANT
Apr 17, 2009 05:56 PM
gschleg84
Aug 20, 2008 11:02 AM
96A4
Feb 16, 2007 12:39 PM
mikeysentra
Sep 30, 2006 04:05 AM
