Sponsored by:
Sponsored by:
Air pump check valve..
Old 09-10-2009, 03:39 PM
Kristian_TT's Avatar
Default Air pump check valve..
What does this valve do? I checked mine yesterday and saw that the vacum hose vas missing. My car is a litte sluggish around 2500-3500 rpms. Could this be the problem?
Heres a picture of the valve:
Old 09-10-2009, 05:04 PM
gwos25's Avatar
EGR valve, or sometimes called kombi valve, basicly, it recirculates exhaust gas into the intake during cold startup to reduce emissions and reduce the load on the cats during warm up. It alone shouldn't make your car sluggish, but the missing vacuum line and leak may be a contributing factor. Replace the vacuum line and see what happens...
Gary
Old 09-10-2009, 08:50 PM
m000035's Avatar
Gary is right on the effect of the vacuum line being disconnected on your car. The valve is part of the Secondary Air Injection system and is only opened during cold starts. You may not have a CEL, you probably have some "low flow" codes.
But just a note about the valve:
I know that many call that valve a "EGR valve". It does look like one. It is designed like one. It may even be able to work like one.
BUT...
My 2.7t does NOT have a Exhaust Gas Recirculation. IF it did pass exhaust it would melt the plastic hose that is connected to it. (see http://en.wikipedia.org/wiki/Exhaust_gas_recirculation for more info on EGR.) My car uses this valve to put clean air into the exhaust to help the cats.
Old 09-10-2009, 11:26 PM
gwos25's Avatar
Ah ha! Thanks for the clarifications Mike! I wondered about that rubber hose, lol. Just goes to show, don't believe everything you read on the internet,
Old 09-11-2009, 02:24 AM
m000035's Avatar
Originally Posted by gwos25
... Just goes to show, don't believe everything you read on the internet,
Most of the time is is worth every penny you spent on it. (I.E. not much.)
Old 09-13-2009, 01:53 PM
Will blocking the EGR system give a positive effect on a petrol engine?
Old 09-14-2009, 06:17 AM
m000035's Avatar
My 1978 Audi 5000 had a EGR system but I think you are talking about the SECONDARY AIR INJECTION SYSTEM (SAI) in the more modern Audi's.
Blocking the AIR INJECTION SYSTEM will only effect emissions during a cold start. How much? ... I don't think much... but many governments think it is a big deal.
To answer the question you actually asked:
If a car came with an true EGR system, it is used to lower NOx emissions during normal operations. For more information, see: http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
While it could be removed and blocked, it MAY require other changes to the engine. It WILL increase the pollution your car puts out.
Pbcrazy
10-03-2012 10:29 PM
A4inMaui
12-27-2010 03:18 PM
The_n
09-09-2009 10:39 AM
heloman28
11-24-2007 01:21 PM
QuickQuattro
05-01-2007 02:04 PM
Quick Reply: Air pump check valve..
