Alot of people having Vibration Problems?
Old Jul 18, 2007 | 01:04 PM
Retard Riot 686's Avatar
Default Alot of people having Vibration Problems?
I noticed alot of owners of A6 owners saying they are having vibration problems. So am I. I have a 1999 and i was wondering what can be done to correct this? Has anyone actually had this problem and how did you go about fixing this. Thanks!
Old Jul 18, 2007 | 01:41 PM
ppgoal's Avatar
Default RE: Alot of people having Vibration Problems?
If you read the responses, you would see that most answerssuggest a wheel balancing, especially if it seems to happen in one speed range. That would be the first thing to check.
Old Jul 18, 2007 | 01:57 PM
marko_tomas13's Avatar
I also now have a vibration around 100km/h and anything slower or faster it doesn't show up.
The problem is a tire bulge though in one of my rear tires. Check the easiest and cheapest things first like tire balancing and then work your way up to real big problems.
Old Jul 18, 2007 | 04:50 PM
cary12's Avatar
I agree with the above. I was having a really bad vibration at 55 mph and I took it in to have the wheels rotated and balanced and they found that my back passenger side tire had a huge bubble in it. I got two new tires, had them balanced and now it's good as new.
I would recommend taking it to have the tires checked and balanced.
Cary
Old Jul 18, 2007 | 06:23 PM
ORIGINAL: cary12
Cary
I hear that, damn Pirelli P6's, i'm going to wait it out for a little and replace all 4 tires with the Exclaim UHP's, i've heard a lot of great things about them and am anxious to give them a shot.
Old Jul 18, 2007 | 06:35 PM
ppgoal's Avatar
I've had no problems with my P6s after 15k miles, other than hitting a pot hole in Detroit two winters agoand tearing one. I also only use them in the winter. On the other hand, my Coopers have been nothing but trouble and I finally confronted Discount Tire and they are replacing them with Continentals. They told me I should stay with OEM tires - and I pointed out that they recommended AND sold me the Coopers.
Look into the Conti's before you make your final decision.
Old Jul 18, 2007 | 07:03 PM
Khardysius's Avatar
Possible causes:
1. Improper tire inflation
2. Bad tire
3. Improper wheel balance
4.Bent rim
5. Out of alignment
6. Wearing bearing
7. Worn tie-rod ends
8. Warped rotor
9. Seizing caliper
Just to name a few...
Old Jul 18, 2007 | 07:58 PM
ORIGINAL: Khardysius
Possible causes:
2. Bad tire
4. Bent rim
5. Out of alignment
6. Wearing bearing
8. Warped rotor
9. Seizing caliper
Vibration is a plague on all car owners. Most of the time it could be a million things.
Old Jul 18, 2007 | 08:30 PM
Yeah something tells me its a bent rim. Thank you all tho for ur input
Old Jul 18, 2007 | 09:15 PM
gmdod's Avatar
Hi, I have an 01 A6 2.7T and I am having a similar problem, he whole front end rattles at 120kmh and over. It is going into the shop on Turhsday, as soon as I hear something I will let yall know.
