Another question about intermittent relay
I read a lot about the hazard relay buzzing, seems common and an OK replacement.
Just not sure if my relay issue is the same thing.
Relay cuts in/out at any duration between 1/4 second and 3-4 seconds per in/out.
when itcut's in it seems to effect the cooling fan and the volt meter on the dash clearly drops to 12.x volts, infact all the dash lights dim a little, then click, and it jumps back to 13.X volts.
Is this the same issue as the hazards?
If not, any ideas?
If not, any ideas?
What is the 'turn signal stock'? wiring or the lever assembly?
oddsocks
Feb 11, 2007 07:44 PM
1999, a6, accelerating, assembly, audi, avant, intermittent, intermittently, lever, relay, signal, signals, turn, works
