Antenna
Old Sep 21, 2009 | 06:41 PM
Audi A6 dope's Avatar
Default Antenna
I have a 01 Audi A6 does anyone know where the antenna is?
My radio is really staticy and sometimes wont work at all.
Old Sep 21, 2009 | 06:44 PM
Chechen_Rebel's Avatar
I have 02 which is the same (c5) chassis, and it is located inside the stereo deck, or more precisely, behind it.
When I bought an aftermarket deck I had to get a new antennae, it's really just a piece of metal (almost a wire) that has a special plug to fit the harness to the deck.
There was no OEM part available that was compatible with my car (I have the Bose Symphony) so I tried an 02 jetta part and it works great.
Old Sep 21, 2009 | 06:51 PM
Wait how did you install an after market stereo?
It looks like there is no room to install it.
Old Sep 22, 2009 | 03:01 AM
m000035's Avatar
The radio antenna is in the rear window. Actually there are several, the combination with the strongest signal is used. Some years have a separate module to select which antenna to use. The stock radio has two (HF and ZF) antenna connectors that connect to antenna amplifiers (one or more depending on the year). These are located close to the rear window. Very complicated system.
Old Feb 12, 2014 | 10:15 PM
thecatsandi's Avatar
The radio powers the amplifier/selector. Is it 12V or less?
Slade
Aug 28, 2011 04:38 PM
Flight5
Mar 28, 2008 09:24 AM
converted
Oct 20, 2007 04:38 AM
Nabooly
Jul 10, 2007 08:45 PM
1.84life
Jun 28, 2006 05:21 PM
