Any idea on what HP?
Old Jul 18, 2007 | 10:12 PM
ahbrit's Avatar
Member
Default Any idea on what HP?
Check my Signature.
I'm curious how my car will perform after all the mods.
I have to wait till mid august for everything cause i'm waiting for the Exhaust from APR which is on back order.
The methanol runs @ 116 octane.
Old Jul 19, 2007 | 11:08 AM
EnviedA6's Avatar
Default RE: Any idea on what HP?
HIGH 14'S
Old Jul 19, 2007 | 01:09 PM
Cappachinoo's Avatar
I ask a question about stock number, this one cat answered back:
"I think stock for a6 is 14.6 at 96mph
I have seen several people in stock form go from 14.2 to 14.8 all depends on th driver"
Its has to be at lease better the a 14.6
Old Jul 19, 2007 | 03:31 PM
ahbrit's Avatar
Member
I Got 14.2 with only Revo Stage 1.
i somehow think with all the add-ons i can get better?
Old Jul 20, 2007 | 04:25 AM
Baskin 4.2l's Avatar
sure you should be able to do better but meth dose nothing unless you tune the car for it and REVO isn't exactly one of the super chips
Old Jul 20, 2007 | 06:15 PM
ahbrit's Avatar
Member
My Revos SPS3 units allows me to retard the timing > 100 Octane and increase boost
Old Jul 20, 2007 | 10:42 PM
ppgoal's Avatar
I don't know what kind of Stage 2 clutch you're getting, but if it's Awe spend the extra and get the matching lightweight flywheel. It weighs 12 lbs to the stock 38lbs (I weighed my OEM on a bathroom scale). A lot less rotational inertia if there's less mass to spin. I'm not even sure you can resurface an OEM fly.
Old Jul 20, 2007 | 11:50 PM
ahbrit's Avatar
Member
i researched this when i asked them to do the clutch. They told me they have had some bad experiences with it......Vibration/clutch not engaging etc
Old Jul 21, 2007 | 10:54 AM
reaper's Avatar
Depending on how soon you want to do this I am doing exactly that now. I am replacing my clutch with Vast Performances Stage 2 and mating it to a Fidanza light weight flywheel at 12.5 lbs. I plan to make piggies while I am in there as well, and will get a GIAC chip when it's all said and done. I've already got DV's in there, new plugs, snub mount, Coil Overs, and new Air Filter. I plan to also look into the rest of the exhaust at a later date. Since this is basically your set-up you are going for, I can let you know how mine turns out in a month or so.
P.S. I went with the Fidanza LW flywheel because it was the cheapest, and I suspect it is identical to the ones everybody else is selling. There are no names on the wheel itself so I'd bet they just buy them from Fidanza and mark them up. I got mine for under $400 shipped. Resurfacing my OEM flywheel was going to be $300 anyways, whats another $100 for some performance?
Old Jul 21, 2007 | 12:45 PM
ahbrit's Avatar
Member
i'll go back to them and ask about this again. I'm just dont want to have to pay all the labor twice cause of a bad flywheel
i hear the flywheel can gain 20hp at the crank, so it is definately something i'll revisit.
wammy18
Aug 13, 2008 03:24 PM
CodyR
Feb 1, 2008 07:14 AM
kraylon
Jun 4, 2007 06:43 PM
papachewlo
May 25, 2007 03:34 AM
rbrtech
Feb 11, 2006 01:46 AM
