Sponsored by:
Sponsored by:
Anyone have any ideas what could be causing these codes?
Old 07-17-2012, 12:37 AM
tehsideshow's Avatar
Default Anyone have any ideas what could be causing these codes?
So my car has been having this issue for over a year where when it's warm it doesn't like to start. More recently it's been stalling randomly unless I give it some gas. I've already checked the temp sensor, ruled it out. Here on the codes, tell me what you guys think ..
VAG-COM Version: Release 409.1-US
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01,02,03,08,15,17,25
Address 01: Engine
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D01
Coding: 06152
Shop #: WSC 02301
8 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17967 - Shareware Version. To Decode all DTCs
P1559 - 35-10 - Please Register/Activate - Intermittent
16706 - Shareware Version. To Decode all DTCs
P0322 - 35-10 - Please Register/Activate - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-10 - Please Register/Activate - Intermittent
16690 - Shareware Version. To Decode all DTCs
P0306 - 35-10 - Please Register/Activate - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 35-10 - - - Intermittent
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 4B0 927 156 F
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 08: Auto HVAC
Controller: 4B0 820 043 G
Component: A6-Klimavollautomat D55
Coding: 00132
Shop #: WSC 02055
Old 07-17-2012, 10:07 AM
z28pete's Avatar
The ECM is seeing a low voltage condition, and this is probably causing all the other problems. May want to check voltage at ECM with a test meter, and make sure all battery and ground cable conections are clean and tight.
Old 07-17-2012, 01:16 PM
My friend said the same thing. I think I'm going to replace the battery and the ground cable for the battery and go from there.
Old 07-17-2012, 05:14 PM
Jeffla's Avatar
what is the voltage output coming from the alternator?
Old 07-18-2012, 11:54 AM
It's showing 14 in the instrument cluster.
Tourbo24
01-26-2012 03:51 PM
A4Chris
09-14-2011 10:14 PM
audistheonlyone
05-21-2009 03:59 PM
TverRus69
10-24-2008 06:58 PM
Quick Reply: Anyone have any ideas what could be causing these codes?
