Audi 100 Quattro front lower arms.
Old May 6, 2009 | 12:36 PM
AudiA8Quattro's Avatar
Default Audi 100 Quattro front lower arms.
Hi, the car in question is a 1993 Audi 100 Quattro 2.8 V6 code AAH. Its very similar to the early A6's so i hope this is the right section!
Anyway, i need to replace both front lower suspension arms, the problem is where the inner bush mounts to the subframe, there is a guide sleeve fitted.
Haynes and Elsawin state that i need a puller to remove the bush, haynes says i might need to remove the subframe to tap out the sleeve
The question is can i remove the inner bolt and collapse the sleeve with a chisel? this is a common method used on mk2/mk3 golf wishbones which i have done before.
Cheers for any help!
Old May 6, 2009 | 11:40 PM
auditech79's Avatar
No, you either need a puller or a press to release the bushing. Mk2/Mk3 golfs are much easier than these bushings.
Old May 10, 2009 | 05:53 AM
Thanks for the reply.
Can you recommend a puller that will do the job?
I do have a press, but surely i don't need to remove the whole subframe just to change the arms?
dave944
May 3, 2015 07:50 PM
dave944
Aug 19, 2013 09:48 PM
Keithr726
Jan 23, 2010 03:57 PM
kevin1533
Jul 27, 2009 12:53 AM
Q_AUDI
Sep 27, 2005 09:52 PM
