Audi 3.0 Lifter (Cam Follower) replacement
Old Jan 22, 2012 | 07:01 PM
Jackmup's Avatar
There are plastic covers held in with metal retaining clips on each of the cam pullies. Replace the plastic covers they will not reseal, you will have oil leaking from them if you re-use them.
You should only remove the cam sensor on the bank you will be pulling the cams from. Cam sensor is the part on the firewall side, adjuster is in the front.
You will be loosening the bolts on the other bank that you are not working on
all bolts will be loosened on all cam pullies
It gets re timed by holding the crankshaft and the cams in position with the tools. then you will adjust the pullies, belt after tensioned.
I'll get some info to you, sorry, I've been pulling my hair out with a 6.5 diesel
Old Jan 22, 2012 | 09:48 PM
jjhackn's Avatar
I have removed the plastic covers with the metal clips, loosened the cam bolts, and removed two of the bolts in the cam sensor. The other bolts in the cam sensor are tough to get to but I haven't tried yet. I haven't done anything to the adjuster yet as I'm not sure how to remove it. I appreciate anything you can send me.
Old Jan 23, 2012 | 02:42 PM
Jackmup's Avatar
I'm sending you 3.0 TB replacement instructions PDF via e-mail
They have nice illustrations
Old Jan 24, 2012 | 03:46 PM
chuckstyl5's Avatar
does the head need to come off to do the follower?
Old Jan 24, 2012 | 05:59 PM
jjhackn's Avatar
Thank you for the pdf documents. They will help me out greatly. I hope to get this fully apart this weekend. I have everything I need except I'm not sure about the cam gear on the front of the cams. I don't know if I just need to take the bolts out and pull the gear off or if it comes off another way.
To answer chuckstyl5's question, I am not taking my head off to replace the follower.
Old Jan 24, 2012 | 07:00 PM
chuckstyl5's Avatar
good to know - i just bought a 2004 a6 3.0 and it has 170K I'm about to do the TB and I'm hoping i won't run into any extra expenses haha --- Can you please forward me that PDF file??
Old Jan 25, 2012 | 09:14 PM
Jackmup's Avatar
no you can replace the followers/Lifters with heads on
Old Jan 25, 2012 | 09:22 PM
  #18
Jackmup's Avatar
Your going to pop the caps
Loosen the bolts and give it a yank toward you they slide off.
They are not pressed on or anything like that
you do not need to mark the location of them
but mark which one went where put them back on the same shaft they came from. If you cant it won't really matter but make a habit of doing things that way.
However Make Sure You mark your Crankshaft location if your didn't manage to get that crank pin in. Did you get it in? or give up like the rest of us?
I have a yellow paint marker from the girly store.
Had to buy something when she dragged me in there
Old Jan 29, 2012 | 09:04 PM
  #19
chuckstyl5's Avatar
Have yet to take the valve covers off to check them yet -- I am working on the intake manifold right now
Old Aug 24, 2014 | 08:48 PM
  #20
prburnsjr's Avatar
I have found a way to get a small ratchet to this plug but i cant get it out. I'm not sure what bit this plug takes but a 6mm allen or a torx bit seems to kinda fit it but are not tight. I made a video but I still can't clearly see what bit i need. Help please!!!
Audi 3.0 AVK crank lock pin? - YouTube
I see you found the crank locking pin location on the 3.0 AVK engine. Unfortunately it looks like your YouTube video got taken down. Any chance you still have it somewhere? I'm having a terrible time finding the proper location...
