Audi A6 1.8 Turbo - Engine jitters and white smoke
Old Jan 24, 2007 | 05:21 PM
Topterry's Avatar
Default Audi A6 1.8 Turbo - Engine jitters and white smoke
When I start my A6 1.8T the engine jitters and doesn't idle at the right level of revs (ie idle at about 600 rather than 1000-110). It then corrects after a little while driving however when I then rev overto 2750 revs the exhaust chucks out a lot of white smoke. Itonly chucks it out atbetween 2750-3100 rpm. If i keep the revs below this there is little tono smoke. I can drive at all variety of speeds but smoke is only expelled at the revpoints mentioned above.If anyone can shed some lightI would be very greatful! Thanks in advance.
Old Jan 24, 2007 | 06:06 PM
dimitri's Avatar
Default RE: Audi A6 1.8 Turbo - Engine jitters and white smoke
never heard of an A6 with 1.8T
Old Jan 24, 2007 | 06:10 PM
techbod's Avatar
yep they make a 1.8T a6 in the UK
white smoke could be coolant getting into the exhaust ( are you loosing any coolant?? )
Old Jan 24, 2007 | 06:13 PM
techbod's Avatar
we also have a 1.8 non turbo - 1.9D TDI - 2.4 - 2.5D TDI - 2.8
Old Jan 24, 2007 | 08:47 PM
Topterry's Avatar
No not losing any coolant. Think I may be losing a bit of oil but not coolant. Have had it suggested that it may be the turbo. Any thoughts on that ?
Old Mar 9, 2009 | 04:54 AM
miloman's Avatar
Default Same problem
Hi Topterry
I have an Audi A3 1.8T (same engine i think) which is doing similar, although i dont appear to be having any engine jitters.
Did you get your problem resolved and if so, what was it?
Thanks in advance
Old May 18, 2010 | 06:34 PM
bradtom's Avatar
yep it should be the coolant problem, had almost similar audi a6 problems.
Vjuice602
Jul 9, 2012 12:45 PM
Ryanb83
May 15, 2011 06:02 PM
chicken1
Feb 10, 2009 06:25 PM
HEJNIS41
Jan 8, 2008 08:42 AM
tj19855
Oct 22, 2007 05:23 PM
