Audi A6 2001 2.8 Check Engine Codes
I hope i can get an advice. Have an Audi A6 2001 2.8. Had a "coolant temperature sensor" code. My mechanic replaced the sensor and also he replaced a bad fog lights fuse. After the job was done the car is not idling correctly. Check engine came back and got 12 different codes:
P0444- evap emission control system purge valve c open
p0418 secondary injection system relay A malfunction
p0010 Camshaft Position Actuator A Bank 1 Circuit Malfunction
p0412 Secondary air injection system valve malfunction
p0057 HO2S Bank2 Sens 2 Heater Circuit low
poo37 H02S Bank1 Sen 2 Heater Circuit Low
p0136 O2 Sensor Circuit Malfunction Bank 2 sensor 2
p0156 O2 Sensor Circuit Malfunction Bank 2 sensor 2
poo31 H02s bank1 sens 1 heater circuit low
poo31 H02s bank2 sens 1 heater circuit low
p0102 MAF or VAF A Circuit low imput
p0134 O2 Sensor CKT No Activity Bank 1 Sensor 1
Mechanic is not answering my calls. can not afford to spend money on this car anymore.
what could cause all this problems?
Juliet
Oct 30, 2012 02:53 PM
