Audi A6 - Stuck in Park :(
Hi
2006 Audi A6 2.0 TDI Auto - I'm stuck in (P) Park and cannot shift out to select another gear. Engine runs sweet
All brakes are perfect, bulbs, fuses, switch checked all electionics working.
I have noticed the Gear selector on the dash is not displaying the gear selected. It should be displaying P but nothing is highlighted
I have pressed the override button under the front ashtray compartment to allow me to more the gear level. Even when I put it in N or D again the gear selection display on the dash is not displaying the gear i'm in?
I had a car auto electicion come and go a code read which on his advanced diagnostic system connected fine and did a full code read.
I have the follow codes which came out
17090 - Transmission Range Sensor F125 - Implausible Signal : P0706
01119 - Gear Recognition Signal
6275 - Park/Neutral Switch
Suggestions please?
Suggestions please?
Hi
Suggestions please?
Suggestions please?
From the little I know - I would guess this is a CVT transmission? If so my next guess would be bad TCM? Either way if you have the non-quattro version you are looking at the CVT and that is almost always the beginning of a bad story. Those things fail left and right all the time.
The specific error message could indicate that it's as simple as a faulty park/neutral switch. You would have to get in there and take things apart and test them before replacing stuff if you don't want to throw money out the window.
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
johnbianco15
Apr 6, 2015 07:23 PM
