Audi dash questions help!
The top one means your low on windshield washer fluid, and the 30mph is probably the average speed you have travelled since it was last reset.
On the lever to the right of the steering wheel there is an up/down switch and a clear button. You can use the up/down to change that to show average mpg, current mpg and other stuff. Use the clear button to rest the value currently displayed.
The top is the low wiper fluid. Carry some with you because that thing scares the crap out of me when it beeps on.
The 30mph is a warning. You can set a warning that comes on when you reach a certain speed. So 30 if you tend to fly down your neighborhood a little fast or if you wanted to set it at 70 to avoid speeding tickets on the highway it will beep and let you know.
As far as the above quote goes, the break light and the ABS light have been checked. Its a bad fuse of some sort. Replacing shortly. All the breaks work and the break light stays on even if the break is down (flashing not solid).
It's not a bad fuse it's the ABS module 99.9% of the time. The flashing light is because the ABS module stopped communicating. It's an easy fix and you can buy the repair service on ebay for $65 from ATE in texas. I sent mine out and had it back in 5 days and its back to working great and they have lifetime warranty on module. Dealer estimate was over $600. ATE will send you instructions if you need them but it is so simple to remove anyone can do it and you can drive it while the module is removed.
Hey all two questions. What would make the red air bag warning ligh on the dash come on. I was in no accidents or anything to make it turn on. Also when I turn the steering wheel there is a slight grinding and whining noise that is hurd any answers for me would be really appricated. It's a 2004 a4 1.8t quattro. Thank you for you're time
