backup lights do not work
First post in this forum.
I have a 1995 Audi A6 2.8 (not a quattro), bought second hand about nine monthes ago.
My backup lights do not work. I have tried all the common stuff. Bulbs, fuses et al. Both do not work so I do not believe that it is the fixture (or receptacle or where ever you put the bulb) so I believe there may be a switch to replace.
1. Any ideas that may help!
2. Where is the switch?
3. Is there any special things to know about before I replace the switch?
Any help would be appreciated!
Tex
Tex
mine worked sometimes, i have 6 speed, so if i put it in reverse lightly it wouldnt turn on, but if i held the shifter into gear and pushed up, they wou;d turn on, audi replaced it under warrenty. i believe its some sorta sensor that needs to be replaced
