Bad Vibrations - Thoughts?
Old Jan 10, 2011 | 08:28 PM
JoshandDawn's Avatar
Default Bad Vibrations - Thoughts?
Past few weeks I have become an expert on drivetrains for my '04 A6 2.7t...which I never wanted to be! I drive far distances for work in my Audi, typically 3 hours one way on Mondays, then back 3 hours on Friday.
On one of my last trips, after about 2 hours of driving, I started getting a very bad vibration coming through my gas pedal and some in the seat of my pants. By the time I arrived at my hotel an hour later, the vibration was so bad that my leg was literally shaking.
To make a long story short, over the past few weeks the car has been in 2 shops, and here is where we are at:
Only vibrates during acceleration, worst from 35-60 mph. Vibration stops when I stop accelerating. NO vibration when braking, coasting, or in neutral.
Only starts vibrating after I have been driving constant for over 2 hours, typically on the highway.
My normal Audi shop is wanting to replace axles/cv joints. I am thinking that or motor mounts, but we figure starting with axles is cheaper (motor mounts on the 2.7t is a 15 hour job...).
Any other thoughts?
2004 A6 2.7t Quattro s-line automatic, APR 93 octane chip, Dunlop winter tires.
Old Jan 10, 2011 | 11:51 PM
chefro's Avatar
It sounds like you have an issue with (constant) velocity and heat generation (out of grease?) The shop probably is right on with replacing the cv axles. Do you have bad CV boots?
If the motor mounts were a problem, then you should probably have felt vibration at idle as well.
Old Jan 11, 2011 | 09:31 AM
The boots look fine, and there isn't any grease leaking anywhere, which I think is why they are going with replacing the whole axle instead of fixing the boots.
Hitting the road again today for a couple hour drive - we'll see if she lasts!
HolyokeAudi
Sep 17, 2014 08:21 AM
vtraudt
Jun 5, 2010 11:58 AM
1.8BEASt
Mar 24, 2009 10:22 PM
black on black s4
Nov 8, 2007 12:38 AM
impaler2383
Mar 11, 2006 03:43 PM
