Blinker Relay
Old Feb 14, 2010 | 10:55 PM
WoodShoe's Avatar
Default Blinker Relay
2001 C5. Starting to have a bit of an issue with the turn signal relay (it randomly clicks) Im sure it will freeze on me any day now... I havent taken a good look into it yet, but it sounds like its under the dash near the glove box. So i assume im going to have to remove the dash to get at it? Anyone have a writeup or instructions? Finding all the mount points/clips is a PITA first time around... thanks.
Old Feb 15, 2010 | 01:10 AM
auditech79's Avatar
Its that red triangle in you dash board, it acts as the hazard switch and turn signal relay. You just need to remove the radio (using the removal keys) then the trim above the radio, release the holding tabs and you're in business.
Old Feb 15, 2010 | 07:22 AM
WoodShoe's Avatar
So im going to have to buy a new switch? or does the switch have the relay attached to it?
Old Feb 16, 2010 | 01:09 AM
auditech79's Avatar
Whole new switch, they aren't that expensive online from what i remember.
EDIT: I take it back http://www.ecstuning.com/Audi-C5_A6-...rior/Switches/
find which of the 3 switches you need by removing yours and taking a look.
Old Feb 16, 2010 | 11:09 AM
hxgaser's Avatar
Sorry to disagree with the master, but you don't need to remove the radio. Just the trim above...
Old Feb 16, 2010 | 06:19 PM
auditech79's Avatar
Im just going by what the factory repair manual says (ELSA WEB) its much easier to push the switch out from the back with the radio removed. If you "don't" have the radio removal tools you can do it the way hxgaser said to do it, but its easy to break the trim clips on that panel above the radio if you don't remove the radio first.
Old Feb 16, 2010 | 08:02 PM
WoodShoe's Avatar
Thanks guys. Switch is about the same price as a relay (found some online)
iastudilloi
Sep 27, 2018 04:41 AM
gahndai
Jan 28, 2011 10:31 AM
qUaTtRoA4
Dec 23, 2009 08:14 PM
norbluto
Nov 18, 2006 05:43 PM
neversummer
Jan 30, 2006 10:34 PM
