Bluetooth
I noticed that my bluetooth disconnect with my phone at times for a min. or two and then reconnects. Also, received and dialed calls are showing me all kind of nos. from my address bookthat I never called before. Is there any software upgrade for Bluetooth only or some kind of TSB? Thanks
It looks like you are running MMI version 11.9.0, which is the original version for 2006. When Audi updated my MMI software about a year ago it was updated to version 33.6.0. I saw on the forum that a recent update resulted in version 41 something. The dealer is lying to you if he is telling you that version 11.9.0 is the current version. If you are still on version 11.9.0 you are still dealing with the bluetooth and other issues that were fixed in later updates. If you want to get the updates you can't tell the dealer that you simply want an update. Instead you have to complain about certain known issues such as the radio losing its "surround sound setting" or the "MMI cursor jumping". Audi knows that both of these problems are intermittent and that they do not throw error codes, so Audi can't verify the condition. As a result, Audijust upgrades the MMI.
You may also want to check the Nav version. For some reason Audi determined that some of the computer issues were fixed with the Nav update, not just the MMi update. What Nav software version are you running?
Good luck.
Good luck.
bwright19
Sep 29, 2008 09:12 PM
bwright19
Aug 13, 2008 07:50 PM
bwright19
bwright19
Aug 13, 2008 07:49 PM
bwright19
Aug 13, 2008 07:39 PM
