Bluetooth - Windows Media Player from PPC
Is there a way to play music from my pocketpc phone (verizon) and have it play in the Audi? I am able to pair it and use my phone with no problem. I have bluetooth headphones that work this way with my phone and since the Audi shows up as a "headset" ...i should be able to play music to it right?
Thanks yall!
Audi A6 '08 - rocks!!!
C
Thanks yall!
C
Your devices need to be A2DP protocol compatible. I thought the 2008 A6 did not have AD2P funtion on the standard bluetooth function, but you can buy an aftermarket adapter for it. Also you need to make sure your phone is also A2DP compatible.
Well... I use my bluetooth headphones to listen to music paired from my phone ...so that means my device does have "A2DP protocol compatible" stereo bluetooth ...i hope my logic is correct here... I guess I was hoping the A6 had this...since it does have AUX for the IPod ....
Any suggestions on adapters for this? And where would I install this adapter?...where the IPOD plugin would go?
Yes it means that your phone supports A2DP. Here is a link I found on the web for an Audi kit, but it is from UK.
http://www.xcarlink.co.uk/product.ph...8&cat=4&page=1
limi
B8 Models
May 11, 2011 08:59 PM
youngie
Apr 24, 2006 12:50 PM
