brake piston wont turn on c5
Changing the rotors and brakes on a 2001 a6 quattro 2.8. I have the tool that turns the piston as it pushes. I have the brake fluid cap off under the hood and I even tried with the bleeder screw loose. THe piston barely turned at all clockwise and will not go in or turn. I put lots of pressure on it and even tapped it with a hammer to try to turn it and nothing? Any thoughts?
LOL Had all the problems mentioned here - including the set screw. Once I had to use a large pair of Channel locks to get the piston to start moving. I probably should have replaced the caliper but I was cheep.
All good comments and sugestions--
Maybe less bull and more work would help the cowboy ride with new brakes!!
