brake piston wont turn on c5
Old Mar 17, 2010 | 05:40 PM
rgall's Avatar
Default brake piston wont turn on c5
Changing the rotors and brakes on a 2001 a6 quattro 2.8. I have the tool that turns the piston as it pushes. I have the brake fluid cap off under the hood and I even tried with the bleeder screw loose. THe piston barely turned at all clockwise and will not go in or turn. I put lots of pressure on it and even tapped it with a hammer to try to turn it and nothing? Any thoughts?
Old Mar 17, 2010 | 07:24 PM
Audion's Avatar
I had a similiar problem using a Harbor Freight tool. I lost the set screw and did not realize I was pushing on the piston and not turning it. I made a new set screw out of a small bolt and it worked fine.
Old Mar 17, 2010 | 07:29 PM
hxgaser's Avatar
Hope you are doing this for the rear brake? Front ones do not require turning. Also did you remember to disengage the parking brake?
Old Mar 18, 2010 | 07:37 AM
rgall's Avatar
Drivers side rear and yes the parking brake is off. This isnt my first rodeo........
Old Mar 18, 2010 | 08:38 AM
bob martin's Avatar
Sounds like time for a new caliper, cowboy.
Bob
Old Mar 18, 2010 | 10:37 AM
NH_USA's Avatar
LOL Had all the problems mentioned here - including the set screw. Once I had to use a large pair of Channel locks to get the piston to start moving. I probably should have replaced the caliper but I was cheep.
All good comments and sugestions--
Maybe less bull and more work would help the cowboy ride with new brakes!!
Freight_Cartel
Mar 4, 2011 02:26 PM
Squareone
Nov 25, 2008 07:58 PM
Tsi88kid
Apr 21, 2008 09:13 PM
hypnotiks
Apr 7, 2006 02:20 PM
paliracer
Feb 21, 2005 03:15 PM
