Brakes
Old Oct 31, 2007 | 08:33 PM
daschief's Avatar
Default Brakes
ok i know you guys must have heard this all the time and i tried finding it on the forum but had no luck. i have a 1998 A6 2.8 Quattro. its a dream to drive, the guy who sold it to me kept all the receipts and he had the suspension, CV boot and Timing belt changed. but the ABS light comes on when i start the car up and after driving for a few minutes it goes off. any ideas? i had the car checked by a service station and the mechanic listed that he "recommends" that i change the brake rotors. could that set off the ABS lights?
thanks
Old Oct 31, 2007 | 10:47 PM
Nocturnal_A62.7's Avatar
Default RE: Brakes
Audi has a standard of 28mm on the rotors for 2.7 T, and for 3.0 and 2.8, it is 23. If your rotors are below the specs, it will give the ABS warning light. It's not expensive anymore, you can get a pair of front rotors from the dealer for about $240 + labour.
Old Nov 1, 2007 | 03:25 AM
Cmoney's Avatar
Default RE: Brakes
If the ABS and brake light comes on together, it could be the control module for the ABS. If it's just the ABS, it could be low on fluid. I would do like Noc suggested and get the rotor specs checked. I have a 2.7 and I got some Zimmerman cross-drilled rotors for about $98 a piece. I put them on myself. Not to bad.http://www.modulemaster.com/audiabsbsrepair.htmlI have to use this service. The dealer wants $900 to do this. Good luck.
Old Nov 1, 2007 | 11:16 AM
Default RE: Brakes
$900?? Thats too expensive. My dealer in Virginia, charges $750 for front brakes. That includes, new rotors, pads, and labour.
Old Nov 1, 2007 | 11:06 PM
DMSD's Avatar
Default RE: Brakes
Did the mechanic check it for codes? If so, what are they? If not, have it checked. Brake rotor thickness is not something that will tripthe ABS light, but could be a safty issue.
Bill
Old Nov 2, 2007 | 12:00 AM
Default RE: Brakes
Bill, I had a similar issue couple of weeks back, so I guess I can say that ABS warning lights do come if your rotors are not thick enough. I had a similar warning, and the dealer checked the brake system and advised me to go for new rotors, and when I got the rotors and pads changed, the warning light went away.
Old Nov 2, 2007 | 12:45 PM
NH_USA's Avatar
Default RE: Brakes
You guys must be rich to be spending that kind of money for rotors and brake parts...
I get loaded-rebuilt calipers for about $110 each and a pair of rotors for around $80 when I decide to do the brakes on my 200QT. I suspect the A6 will be about the same.
I use Force Five in Concord NH for most of my parts. 603-223-6700 Chris Semple deals in used, rebuilt and new Audi VW stuff.
Old Nov 2, 2007 | 01:06 PM
Default RE: Brakes
NH_USA, no offence, but if I was to worry about spending on maintenance, I would have got myself a Corolla. When you buy expensive cars, you pay more money for maintenance. In return, you get the quality ride, tons of features, and a feel, which only German cars can provide.
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
