Brass TEE(spliter) for Coolant water pipe
After a short drive, myA6 Qutr 1998 gotwhite somg under the hood. So, I opened hood and removed engine cover to
see wha't goin on.At the moment,Ipulled up coolant hoses, and the plastic spliter cracked, hot water sprinkled atme..
man~ it was over 108 hot day. I walked to Kragen for 45 minutes, andboughtAny color coolant water and "brass tee"
instead. Brass won't be cracked or worn, right?
Things to do; 1. get it changed again with Pentosin Red Coolant.
2. figure it out where the smog comes from.
I could not find a brass one when I had to change the T...make sure you also get some screw type clamps, as when you took of the old ones they will not be as tight and leak...trust me I went through this a month ago
