Name This Coolant Pipe! A4 1.8t
Old Feb 10, 2014 | 09:47 PM
darknezz7's Avatar
Default Name This Coolant Pipe! A4 1.8t
Customer has a coolant leaking 2001 a4 1.8 turbo fwd.
He sent me this very clear picture of where it is leaking from.
I recognize this as behind the alternator on the block next to the t stat housing.
It looks like there should be a tab that goes up to where what looks like a broken bolt is to hold the pipe in place.
What is the part number or name of this coolant pipe? I have not seen the car physically so I am having trouble finding what pipe it may be.
I will be replacing t stat housing and t stat at same time since its right there.
Is it this one http://www.ebay.com/itm/01-AUDI-A4-RADIATOR-COOLING-HOSE-PIPE-/160655414804?pt=Motors_Car_Truck_Parts_Accessories&hash=item2567cf1614&vxp=mtr?
Thanks for any help!
Old Feb 10, 2014 | 10:47 PM
Audi Tek's Avatar
Tech Certified
no its not that one....
but your right on its location...
have whoever it is send another pic more zoomed out... because that pipe gets replaced with the notorious rhino plug in 2002.
Old Feb 10, 2014 | 11:12 PM
darknezz7's Avatar
Yeah I see 2001 is a split production year
someone should be able to tell by the t stat housing which this is though?
AVJ,AMB,BFB, BEX
ADR,APT,ARG, AFY,APU,ARK, AJL,ANB,AWT, AVV
Old Feb 10, 2014 | 11:16 PM
darknezz7's Avatar
heres the other pic he sent me
Old Feb 11, 2014 | 12:44 PM
darknezz7's Avatar
vin is
wauac68d71a057262
hmm I nice vin decoder right in the forum. but it doesn't say engine code, does saw 170hp though so that is the awm?
Old Feb 11, 2014 | 01:52 PM
darknezz7's Avatar
This is off a ebay parts place
#21?
this kinda looks like it but I don't see that small side outlet on clients car.
Need to figure this out! I guess I need to determine exactly which head was used? Should be AWM engine right?
Damn these vw's and audi's using so many combos, finding a alternator for a 99 passat 1.8t was a nightmare.
Old Feb 11, 2014 | 02:12 PM
darknezz7's Avatar
wow.
looking in parts catalog I get a different thermostat housing every year for the 1.8t
2002
2001 (what this car is and it matches the pic)
2000
I cannot find that pipe next to it anywhere!
Old Feb 12, 2014 | 12:22 AM
darknezz7's Avatar
help?
So I had him confirm, this is a metal pipe.
I should just need the o rings, are they the same size for all pipes generally?
Do I really need to do the t stat housing or just the gasket?
Old Feb 12, 2014 | 12:54 AM
darknezz7's Avatar
these?
W0133-1641058
DPH
Stocking Part Number : 058121687
Engine Coolant Pipe O-Ring; O-Ring, 31.5x3.65mm; Pipe to Cylinder Head Hose Flange
or this?
N90365302
Corteco OEM
Engine Coolant Pipe O-Ring; Pipe to Thermostat Housing; 20x3mm
Old Feb 13, 2014 | 02:05 PM
darknezz7's Avatar
No help huh?
I'll just order all the sizes I guess.
