Sponsored by:
Sponsored by:
Burning Engine
Old 06-08-2009, 06:16 AM
twinturbosixer's Avatar
Member
Default Burning Engine
Hello all,
Some of you may recall me mentioning that over the weekend I was having my Cam Adjuster seals and Valve Cover Gaskets replaced. Prior to having this done, I was smelling a nasty smell coming from my engine every time i came to a light or had the car stopped.
Well, come to find out, the burning smell/smoke was not oil burning from the leaking seals.
When I got home from having the work done, I washed out the engine with degreaser (Im talking hard core under the car with a scrub brush and a high pressured hose).
I drove around for a while and sure enough, the smell came back along with the smoke.
The smoke is white, and almost has the smell of burning rubber, but is coming from the left and right sides of the engine, and the smoke is coming out of the wheelwells.
ANY ideas guys?
Thanks!
Old 06-08-2009, 07:09 AM
jallen3521's Avatar
on my 2000 2.7T I had the same problem and it turned out to be the secondary air pump hose melted through because the secondary air pump was inoperable. Not sure if this is the case on yours or not
Old 06-08-2009, 08:36 AM
Member
can someone tell me where the secondary air pump is located on the engine?
Thanks!
Number 5
Audi Q5
24
06-17-2017 01:04 AM
bryan0
06-06-2011 08:06 AM
KinkySlayer
01-14-2011 04:05 PM
Venavatio
B8 Models
08-07-2010 04:58 PM
LKaler
03-25-2010 10:14 PM
Quick Reply: Burning Engine
