C4 headlight switch
Old Feb 24, 2010 | 10:01 PM
NH_USA's Avatar
Default C4 headlight switch
Does anyone have experience with the headlight switch? (97 Avant 2.8 last of the C4 bodies!) Or a sugestion as to how to stop it from breaking?
I'm going to replace the switch for the third time in 3 months. I'm getting pretty quick at pulling the air bag and steering wheel but I'm getting tired of doing it over and over again. I might be wearing out the screws!
In Dec the first switch failed and I put a used one in. A few weeks later it failed so I put another used one in - (covered under a guarantee) thinking that it happens sometimes. Now the third one has failed in the same way - the headlight contacts. I took the first two that failed apart, found the offending contact, and was able to put something together that worked. It looks as if there is a bit too much heat, a little plastic piece is melting/softening and stopping the contacts from making good contact.
I'd like to think it is just a fluke but don't know for sure. The contacts power the fog lights and the low beams thru the lamp control module.
Maybe I'll just use a toggle switch! LOL
Old Feb 25, 2010 | 07:45 PM
a6hcw's Avatar
You could have a short circuit or oxydized contacts, which cause the excess heat to melt the plastic. I have never had any problems yet with the headlight switch. I did take the speed control switch apart on a 1998 Audi A6 wagon and the circuit board was badly tarnished. I used steel wool to remove the tarnish and then a thin coat of silicon dielectric grease to prevent it from oxidizing again.
Old Feb 26, 2010 | 12:31 PM
NH_USA's Avatar
Since I put two switches together for this try, I cleaned the contacts and used dielectric grease.
I haven't had time to look at the last switch so I don't know why it failed. Until I figure it out I'll leave the fog lights off to keep the current low.
99A4NOW
Mar 28, 2011 08:51 AM
Kaufman1009
Jun 29, 2010 08:40 PM
Influentialstylez
Mar 29, 2007 04:30 AM
LUVmyA4
Feb 14, 2007 02:11 PM
krisdebo
Jun 18, 2005 08:41 PM
