Cam shaft postion sensor metal wheel?
Old May 22, 2011 | 08:40 PM
Killmon's Avatar
Default Cam shaft postion sensor metal wheel?
So, I have my cams out and i need to remove the metal wheel that the Cam position sensor reads, anyone know how? And how to make sure it goes back on in the potion?
Thanks!
Old May 23, 2011 | 09:23 PM
Killmon's Avatar
Default bumpidy
Bump, anyone? Sorry for being impatient...
Old May 24, 2011 | 01:11 AM
chefro's Avatar
You should list what yr model you have, or maybe just post a pic illustrating what "wheel" you're talking about.
Old May 24, 2011 | 10:21 PM
Killmon's Avatar
Default Cam Psotioon trigger
It is an 2001 A6 2.8, but all Audi's with cam sensors will have the same part. it is actually the Cam positioning sensor trigger plate. It is the part that is attached to the cam that the sensor reads to determine its position of the cam. I marked it with with a marker and removed it as it needs to be removed to replace the rear cam seal that precedes it. I did not need to mark it as there is a little tough that fits in a grove in the cam that lines it up. The question I have not is what its the torq spec to the bolt that holds it on the cam?
Old May 25, 2011 | 02:35 AM
chefro's Avatar
Is this what you're talking about?
"CMP Sensor Plate - 15 ft lb"
The two bolts holding the sensor itself - 7 ft lb
nickvanik
Mar 10, 2012 06:30 PM
neomaxddr
Apr 1, 2009 03:16 AM
RichardAllroad
Jun 13, 2008 10:24 PM
datdonnguyen
Mar 4, 2008 12:42 PM
daviees
Oct 23, 2007 07:05 AM
