crank shaft sensor
Old Mar 3, 2008 | 12:05 PM
datdonnguyen's Avatar
Default crank shaft sensor
does anyone out there have a diagrame or know where the crank shaft sensore is located. I bouth one to replace and can't find the dam thing anywhere. it should just be a replacement right?
Old Mar 3, 2008 | 02:52 PM
Red_sapphire89's Avatar
Default RE: crank shaft sensor
why did you buy a replacement? Did you get a cel? All that sensor is, is a magnet its incredibly rare for it to go bad or break on any vehicle. Chances are you got a problem with your timing belt..it may have stretched or something tensoner gone bad....Why do you think its the sensor?
Old Mar 4, 2008 | 12:19 PM
The car starts fin and it runs but when i shut it off after its hot from funning it want start again. starter battery is fine i get a cod P0322. advise please.... ty
Old Mar 4, 2008 | 12:28 PM
that sounds like your correct it is the sensor thats just extremly rare...but does happen i guess
the crank position sensor is heat sensitive when the engine is warm or hot it can malfunction and causes the engine to stall, after it cools for 10 min, it can start again. The problem is is heats up and oil contaminates the sensor and it loses its reading off of the teeth on the flywheel. Replace the sensor but also make sure you fix any oil leaks in that area so it doesn't happen again.
thats the most likely explanation... but yes you are correct its deff your sensor im 99% sure
but to be 100% id check the following:
1) make sure you are getting spark in all 4 cylinders (maybe bad coilpack)
Edit: To answer your original question
The crank sensor is located on the front of the engine to the right of the oil fiter when standing looking down at the car. Looks like a knock sensor.
Old Mar 4, 2008 | 12:40 PM
thanks bro .... people like u make life barable when your babby is all F_cked up. thanks so much.... Don
Old Mar 4, 2008 | 12:42 PM
your very welcome let me know if you still have trouble with anything
mwabask
Mar 26, 2015 08:29 AM
wings7351
Sep 14, 2012 08:51 AM
johnnycakes
Sep 5, 2010 09:45 AM
neomaxddr
Apr 1, 2009 03:16 AM
quiktsi
Feb 9, 2009 06:07 PM
