Can anyone help me find..........
Old Oct 24, 2009 | 11:19 PM
cummins king's Avatar
Default Can anyone help me find..........
i need help finding the temp sencer and the ETG's sencers, and how to get to them
My car is a 2000 Audi 2.7T 6spd
Thanks
Old Oct 25, 2009 | 10:42 AM
Siricospeed's Avatar
Default Temp sensor and egt locations
The coolant temp sensor is located on the cylinder head cross over tube at the back of the motor. It is on the driver's side.
The EGT probes are located in the turbo housings also at the rear of the motor. The egt probes are wired to the sensor located on the passenger side of the rear of the intake manifold. The sensors look like a large matchbox and are black and brown in color. (I believe) They are bolted together. These will be a little tricky to remove as the wires from the probes to the sensors snake around a little bit.
Good luck
Old Oct 25, 2009 | 01:03 PM
Thanks
mikees501
May 10, 2012 12:39 PM
b5audi1.8t
Apr 14, 2009 05:47 PM
auditurbo381
Sep 27, 2007 12:50 PM
Propagandalf
May 10, 2006 10:18 PM
