Can anyone help me find..........
i need help finding the temp sencer and the ETG's sencers, and how to get to them
My car is a 2000 Audi 2.7T 6spd
Thanks
Thanks
The coolant temp sensor is located on the cylinder head cross over tube at the back of the motor. It is on the driver's side.
The EGT probes are located in the turbo housings also at the rear of the motor. The egt probes are wired to the sensor located on the passenger side of the rear of the intake manifold. The sensors look like a large matchbox and are black and brown in color. (I believe) They are bolted together. These will be a little tricky to remove as the wires from the probes to the sensors snake around a little bit.
Good luck
Good luck
