Can I substitute tranny fluid?? $23 per liter at stealership
Old Dec 12, 2009 | 12:56 PM
hottubbrad's Avatar
Default Can I substitute tranny fluid?? $23 per liter at stealership
Is there a tranny fluid that I can get from a parts store that will perform the same (or better) than the Audi German fluids....?
I have an 03 A6 2.7....using G 052 162 A2 fluid.
Thanks
Old Dec 12, 2009 | 01:51 PM
ryuuoh's Avatar
I wouldn't put anything but the Audi fluid in my trans.
http://www.blauparts.com/audi/audi_f...nsmissionfluid
Old Dec 12, 2009 | 03:48 PM
Kevin's Avatar
I would stick with OEM and consider yourself lucky that you don't have a C6. The OEM fluid at the stealer is nearly $90 liter.
Old Dec 13, 2009 | 05:28 AM
Midniteoyl's Avatar
Mobil 1 ATF BEATS the German fluid according to ZF. Pentosin only meets the standard duty specs, Mobil 1 meets both the standard and commercial duty specs..
Old Dec 13, 2009 | 07:29 AM
Kevin's Avatar
Here is a link to ZF's October 1, 2009 list of approved fluids for its various transmissions.
http://www01apps.zf.com/kst464/ZF_In...011_en0700.pdf
Old Dec 13, 2009 | 04:09 PM
Midniteoyl's Avatar
Looks like Pentosin fell off the list...
Mobil is on this list & the tougher TE-ML 14..
Old Dec 13, 2009 | 05:28 PM
nm3210's Avatar
Old Dec 14, 2009 | 12:05 AM
Jeffla's Avatar
Mobile 1 is commonly used among the e46 bmw owners with the same TIP tranny as our beloved C5 A6's.
I have generic esso fluid in mine, put in by a local tranny shop. They will sell it to you in quarts for cheap.
Old Dec 14, 2009 | 06:52 AM
Kevin's Avatar
Read again Pentosin is still there and it is still the fluid that Audi puts in.
Old Dec 14, 2009 | 01:20 PM
Midniteoyl's Avatar
Opps.. did miss it
iluvematchbox20
Apr 22, 2014 04:26 PM
hiwords
Jul 17, 2009 06:45 PM
johnstef
Dec 6, 2006 08:37 PM
audia4quattro
Apr 23, 2006 01:52 AM
