Car computer port
Old May 18, 2007 | 07:34 AM
glock40's Avatar
Default Car computer port
Has anyone ever changed the port from the cars computer? This is the port that you use to hook up your diagnostic machine. The port has gone bad in my 1999 A6 and I can't communicate with my car. If you have changed it is it hard and expensive?
Old May 18, 2007 | 11:15 AM
SSn's Avatar
SSn
Default RE: Car computer port
It's simple ellectrical connection with couple dozens of pins. what's wrong with it? Bent pins? You can fix that. Or you can get any used obd2 connector as long as it has enough wires on the back, gut yours off, and put the other one on, connecting wires to the same position in relation to the connector as before.
It's nothing hard, cut and paste. Well, you might have to unscrew something to remove it behind the dash....
Old May 20, 2007 | 07:32 PM
Avant2k's Avatar
I'm having the same prob,I have had the car 3mths now,checked the diagnostic since I've had it,it was all good.Took the car for my inspection,no go,cant communicate with car.The only time I messed with port was when I bought a $11 vag cable off of Ebay.It did work.Should I assume the worst(ECU),or the connection.What the stats on something like this?
Old May 20, 2007 | 08:17 PM
glock40's Avatar
Did you get yours Avanyt2k ?
techh3ad
Aug 7, 2012 10:47 AM
Leppersmith
Apr 13, 2011 02:48 AM
00Audi180Q
Dec 26, 2008 09:49 PM
SickBoy
Jul 11, 2007 01:01 AM
offroad911
May 31, 2006 05:50 PM
