center consol cup holder
Old Sep 8, 2008 | 11:20 AM
afstud6900's Avatar
Banned
Default center consol cup holder
i was wondering if anyone knows how to remove the cup holder from the center consol, the cup holder to the right of the e-brake that pops up, mines jammed up and i bought a new one and need to replace it. thanks!
p/s its a 99 a6
Old Sep 8, 2008 | 02:36 PM
nm3210's Avatar
Hey, where did you get the new one? Mine is broke and it'd be nice to replace it as well.
Here is a blowout of the design:
Old Sep 8, 2008 | 02:42 PM
afstud6900's Avatar
Banned
unfortunatly i had to get it from the stealership it was 76 bucks...ugh w/e i just dont know how to fix it...
Old Sep 10, 2008 | 02:12 PM
pcochrane's Avatar
With the cupholder open you can see a little tab on each side near the front about a half inch down. Press the tab in on one side with a small flat screwdriver and lift that side up just enough so the tab stays depressed then push in the other tab and lift out the front end of the holder first. It should come right out then. It's tricky to get both tabs depressed - making a jig that could push both in together would simplify the job.
Old Dec 20, 2008 | 09:42 PM
chung373's Avatar
Member
Hey,
I'm a nooob at cars haha.
Can anyone explain how to take apart the center cousul so I can get access to putting in the new cup holder? I have the same problem as the op'er but i have no clue as to where to start.
-Stephen
Old Dec 21, 2008 | 03:07 AM
chefro's Avatar
Somewhat on-topic, or in the vicinity...
Is there a light bulb under the shift **** that illuminates the gears-display cover plate? On every car I had so far was always able to see the gear selection when dusk/night and turning the lights on.
I mean I already got used to shifting "in the dark", yet it would be nice to know if it should have a bulb that maybe is burnt.
If it has one and is burnt, how does the cover plate come off?
Thanks.
punchabear
Aug 23, 2015 02:48 PM
Veedubyaguy
Jun 27, 2014 01:38 PM
Turbo123
Jan 5, 2014 02:59 PM
lexdohc
Jun 25, 2013 06:30 PM
davidaguiar
Jul 26, 2006 04:52 PM
