Chainging the timing belt
Old Dec 14, 2006 | 01:41 AM
dubd012's Avatar
Default Chainging the timing belt
I had a question..
How do I go about changing my timing belt? As in I have a mechanic that is certified. I havent asked him, but I was going to buy all the equipment necessary.
Out of all these, what do i need or is recommended to change?
Cam Chain Tensioner
Cam Follower
Cam Plug
Camshaft Position Sensor
Camshaft Seal
Camshaft
Connecting Rod Set
Crank Seal Cover Gasket
Crankshaft Pulley
Crankshaft Seal
Cylinder Head Bolt
Cylinder Head Gasket Set
Engine Mount Stop
Engine Mount
Exhaust Manifold Gasket
Exhaust Valve
Intake Manifold Gasket
Intake Valve
Main Bearing Set
Main Bearing
Piston
Position Sensor O-Ring
Rod Bearing Set
T-Belt Tensioner Damper
T-Belt Tensioner Lever
Tensioner Gasket Kit
Timing Belt
Timing Chain Tensioner
Timing Chain
Timing Belt Roller
Valley Pan Gasket
Valve Cover Gasket Set
Valve Guide
Valve Keeper
Valve Spring Retainer
Valve Spring
Valve Stem Seal
Wrist Pin Bushing
Thank You
Daniel
Old Dec 14, 2006 | 02:35 AM
SouthboroAudiGuy's Avatar
Default RE: Chainging the timing belt
Go to www.purems.com. They have an all-in-one kit that contains everything you need.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
