Changing springs
Has anyone ever changed the springs on their A6 quattro themselves (just the springs, stock struts and shocks to stay)? I am getting quotes around town in the neighborhood of 500-600$
which seems high so I am considering it myself.
If you have, i'd like to know if it was difficult to do, and what tools I'd need beyond a spring compressor. thx!
which seems high so I am considering it myself. If you have, i'd like to know if it was difficult to do, and what tools I'd need beyond a spring compressor. thx!
I would recommend that you replace struts too, while replacing the springs. Otherwise, you will have really rough ride. As for the replacement, it is pretty straight forward. You do need a spring compressor in addition to the normal tools. I believe there is a DIY at audidiy.com
[QUOTE=hxgaser;969088]I would recommend that you replace struts too, while replacing the springs. Otherwise, you will have really rough ride. As for the replacement, it is pretty straight forward. You do need a spring compressor in addition to the normal tools. I believe there is a DIY at audidiy.com[/QUOTE
Thx for the heads-up. I'll look for the DIY. Why the rough ride with stock struts? I bought some street springs just to drop it an inch and figured the rates were similar to my stock set up. thx again.
$500-600 is definitely on the high side, I paid $400 and still walk with my head down when I think about it. I found a great local shop is offering the job done for $200+/- (Genesis in Rancho Cucamonga, CA)
My main concern is that the stock shocks aren't valved for the performance spring rate, and will wear out prematurely, thus requiring replacement. Let's say you get the springs installed for $400, then within the year need shocks installed for another $400 (just in labor) ~ The shocks are removed and reinstalled during the spring swap, so why pay the labor twice?
Pay up front, set it, & forget it! That's $400 in your pocket for something else (unless of course your going to DIY, but it is still a 3 hour job)
porschenaround
B7 Models
Mar 9, 2018 07:59 PM
kwheels
Oct 28, 2013 10:23 AM
88notchblown
Sep 27, 2009 01:34 PM
Quattro190
Aug 11, 2008 11:57 AM
