Check Engine and 9 codes. Guys help me.
Old Apr 28, 2008 | 05:42 PM
jcyj2's Avatar
Default Check Engine and 9 codes. Guys help me.
My 1998 A6 2.8Q. has 157000 miles.
Runs good, just some vibration exists while stop.
I checked the codesat theAutozone.
P0300 : cyl
P0303 : cyl3
P0302 : cyl2
P0301 : cyl1
P0455 : Evap ECS leak(large)
P1857 : Manufacturer Transmission C
P1138 : Fuel Air Metering
P1136 : Fuel Air Metering
P0102 : MAF Circuit low input
So, about the1st to4thcodes.. I've hadnew spark plugs and wires. Then, probably the coilpack problem, am I right?
Anotherfive codes.. I have no idea.. Please give meany advices.
Old Apr 29, 2008 | 01:37 AM
AudiTech616's Avatar
Default RE: Check Engine and 9 codes. Guys help me.
P0102= You may need a new Mass Air FLow Sensor. And faults P1138 & P1136 could be related to that fault.
P0455=You have a large leak in your Evap system. CHeck your gas cap and see if it's even closed.
P1857= Don't know. Might have to ask the dealer for Specifics on that code
Old Apr 30, 2008 | 06:49 PM
jcyj2's Avatar
Thank you sir.
By the way, light turned off.
No lighting on now, but I am going to do what I have to.
audiopomo88
B7 Models
Dec 29, 2014 07:21 PM
Turbo123
Nov 15, 2011 05:38 PM
nuba4
Jan 13, 2011 05:50 PM
afstud6900
Apr 3, 2008 01:05 PM
bootlucky
Jul 10, 2007 03:48 PM
