Check Engine Codes
Old Dec 28, 2014 | 07:10 PM
audiopomo88's Avatar
Default Check Engine Codes
Hi!
I've had my 2006 A4 for over a year now and have checked the site for small things but thankfully haven't had to post anything because I haven't had any problems... until now!
Have some check engine codes I was curious about, place I take my car has a reader but it doesn't say what the specific code is (is that a thing?).
P2181
P3138
P2008
P0648
I'm sure there might be a place these codes and issues are already posted but some in depth analysis would be great!!
Thanks ya'll!
Old Dec 28, 2014 | 09:28 PM
B7Night's Avatar
The P2181 relates to the cooling system. I had that code, and it turned out to be the thermostat. The engine couldn't heat up, and the heater was pathetic.
The P0648 relates to the vehicle immobilizer.
The other two relate to the flaps in the intake that control airflow into the engine. One relates to an electrical malfunction with the flaps, and the other says they were in the wrong position if I understand it right.
Old Dec 29, 2014 | 09:39 AM
KingWulfgar's Avatar
Yep. You could try replacing the coolant temp sensor first (it's cheaper and easier to get to), but 9 times out of 10 it's your thermostat.
If you haven't had it done and qualify, there's a "customer service action" from Audi that should cover that. They replace the PCV, intake manifold runner motors, low pressure fuel sensor, and maybe one or two other things along with it. Take it to a dealership--they'll tell you they will charge you to diagnose it, but if they end up finding that they need to do that free customer service action, they'll waive the diagnostic fee.
Old Dec 29, 2014 | 03:03 PM
imaudi5000's Avatar
yea i just had my intake flapper motor replaced for free at the dealer under the extended warranty/TSB
Old Dec 29, 2014 | 07:21 PM
Thanks for the posts guys. It ended up back in the shop, got a flat tire today. Can't catch a break recently.
kashmiriomar
May 12, 2010 09:15 AM
Stevenw83
Jan 14, 2009 06:24 PM
millenia
Nov 22, 2008 01:26 PM
afstud6900
Apr 3, 2008 01:05 PM
com2255
Apr 21, 2005 08:52 PM
