Check engine code
Old Nov 16, 2007 | 09:38 PM
JoJo03's Avatar
Default Check engine code
Hey everyone,I have a 2003A6 Quattro and my check engine light is on and I dida scan with the scan tool and it read out two codes, (1) evap emission control system leak very small, (2) evap emission control system purge flow fault. Does anyone have any clue on what the issues is?
Old Nov 17, 2007 | 08:47 PM
dankhound's Avatar
Default RE: Check engine code
Most likly you have a evap purge valve that is stuck part way open causing a leak in the evap system and improper flow from the evap system to the engine. Check to see if the purge valve holds vacuum. If it doesnt, replace it.
Old Nov 17, 2007 | 11:08 PM
JoJo03's Avatar
Thanks alot, what kind of effect can it have on my car in general?
Old Nov 18, 2007 | 10:26 AM
dankhound's Avatar
If thats what the problem is it will have minimal effect on how the engine runs.
Old Nov 18, 2007 | 10:41 AM
techbod's Avatar
but it will damage the catalyst so what was the codes?? the EVAP system is there to protect over fueling and damage to the cat, its a story on its own
MikeA407
B7 Models
May 17, 2014 09:56 PM
ChitownSLine
Mar 16, 2008 08:00 PM
Deekster22
Sep 7, 2007 07:59 AM
MilitantGrunt
Nov 1, 2006 09:16 AM
Fieldy
Dec 30, 2004 09:23 PM
