check engine light
Old May 12, 2006 | 05:41 AM
hamsolo's Avatar
Default check engine light
i have 2001 A6 2.7 biturbo
i recently serviced transmission and within a week check engine light came on
i don't recalled the code but it explain "lock-up clutch coupling no power transmission" within torque convertor
car is driving fine. no shifting problem and no gas milege dropping.
mechanic checked fluid level and everything seems to be fine.
it is just driving me insane....
anybody have any idea????????
Old May 12, 2006 | 09:29 AM
techbod's Avatar
Default RE: check engine light
the code is important
Old May 13, 2006 | 01:06 PM
dankhound's Avatar
Did you fill it to the proper level with the correct fluid? That code refers to a failure in the lockup torque converter. If the solenoid is working ok and fluid is ok your gonna need a new torque convereter.
Old May 13, 2006 | 02:34 PM
AudiTech04's Avatar
Oh no the dredded torque converter code strikes again
All because of a failed little O-ring, its so sad
Old May 13, 2006 | 05:58 PM
hamsolo's Avatar
what do you know about failed o-ring?
is that common in audi tranny?
and what kind of performance is it gonna affect?
Old May 14, 2006 | 02:32 AM
AudiTech04's Avatar
It means you need a new converter
Not to sure about perf wise
Old May 20, 2006 | 01:58 PM
dankhound's Avatar
It will effect gas milage during cruise situations. It can also damage the transmisiion. The torque converter has some slippage. The lockup eliminates that slippage causing all engine power to be transfered to the transmission. It also reduces heat builtup in the torque converter.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
