check engine light on, obd code = 1411
Old Jan 18, 2008 | 07:28 PM
jchadbourne's Avatar
Default check engine light on, obd code = 1411
My car is a 1997 Audi Q6 Quattro Wagon with 125,000 miles. i just picked it up recently and it seems to run fine, but the check engine light came on the other day. i stopped at autozone and they checked the code - the only code was 1411. Any thoughts?
Old Jan 18, 2008 | 08:05 PM
auditech79's Avatar
Default RE: check engine light on, obd code = 1411
Sec.Air Inj.Sys.,Bank2 Flow too Flow
Not something thats going to damage your engine. Its probably a broken vaccum line to the combi valve on the back of the cylinder head on the driver's side. That or the SAP pump is bad.
Old Jan 20, 2008 | 04:28 PM
thank you auditech79! i will inspect the vaccum lines. what is the sap pump? i assume it is an air pump of some sort. thanks again.
motomonkey
Jan 13, 2009 06:18 PM
ChitownSLine
Mar 16, 2008 08:00 PM
shkenned
Jul 22, 2007 06:28 PM
SnowSurfns
Jul 9, 2007 11:27 PM
akindy
Jul 2, 2006 04:01 AM
