Check Engine Light Problem Please Help!
Old May 7, 2008 | 04:11 PM
2000_2.7t's Avatar
Default RE: Check Engine Light Problem Please Help!
So what should I do with my car at this point, it drives great it just has the CEL light on, would o2 sensors or a cat be worth it? I beth the dealer would LOVE to sell me a new cat....
Old May 7, 2008 | 09:02 PM
NH_USA's Avatar
Most states will not allow you pass inspection with a CEL on, so youi'll need to get it fixed. I would first try a reset to see if it comes back on.
Do a search for VAGCom and get one! I't will pay for itself quiclky.
Old May 8, 2008 | 12:26 AM
2000_2.7t's Avatar
Is there an easy way to reset it? Disconect the battery?
Old May 8, 2008 | 06:03 PM
hxgaser's Avatar
You need either VAG com or a code reader. Autozone sometimes will clear the code for you.
Old May 8, 2008 | 09:35 PM
leave it stock's Avatar
Hello,
Sometimes finding yourself a good independent mechanic is the only good answer. Many of these suggestions are right if you want to mess with your car ALL THE TIME. I want to drive my car not learn to map the air fuel mixture at x altitude and y rpm!!!! If you find a competent person or shop you can trust they will explain the situation (as far as state laws and the potential for catalyst damage, a proffesional is needed frequently to steer you through the B.S.) Most good independant's will help a first time customer at little to no charge to gain his trust and show his knowledge if he has much. Just my 1.5 cents MIke
Old May 9, 2008 | 12:49 AM
2000_2.7t's Avatar
thank you all very much for the replies, just as I thought the codes it throws are infact false. My CEL turned off today.I think this means I cannot trues my car's CEL, what does everyone think?
Old May 9, 2008 | 01:39 PM
NH_USA's Avatar
leave it stock - If you want to just "stab and stear it" what you say is OK. But there are a lot of people that want more.
The "mess with your car ALL THE TIME" commentis overstated. Many people that have a VAGComs are not into re-programmingtheir weasel-docks or thing-a-ma-dubs. They use the VAGCom to see what the CEL means so they don't get ripped by a mechanic.
It dosen't take long for someone that reads this forum to see that knowing why the CEL is on important.
Old May 9, 2008 | 06:56 PM
  #18
joetm's Avatar
^^ I second that ... vagcom was the first thing i bought i got it before all my mods
Old May 10, 2008 | 11:07 PM
  #19
hxgaser's Avatar
ORIGINAL: 2000_2.7t
I say don't worry about anything for now. If the same codes come back later, then I would start worring about it.
Old May 17, 2008 | 12:38 PM
  #20
2000_2.7t's Avatar
Well I got the CEL back and it is throwing the exact same codes, what should I do?
