chip and.......
So I will be ordering the APR chip this week for my 01 2.7 TIP Question I have is what is next item in line that I should purchase. the Bi-pipe or DVs. not sure which is next in line. please help. thank you
pick up a pair of DV's. Can either go 710N's which will run you under 100 for both, or get hyperboost, apr, baily's for around 300 for both. You can also order a samco TBB for under 100 instead of speading the 300+ on the bipipe, its up to you.
well its supposedly bad to do DVs after u chip because when u flash the ecu it will adapt to factory DVs and if your car has mroe then 80k on it most likely one has failed ... i chipped and then did DVs and nothing happened but i installed the DVs about 2 days later ... so its up to you ...
Put an ITG/K&N drop in air filter in as well unless you already have an intake. I have seen the factory paper air filter collapsed into the bottom of the air filter box after cars have been chipped.
OOOO
ORIGINAL: liquidcolombian
ok. well i will probably do DVs as well but will i be ok without the Bi-pipe ? at least for a little while ? car is an 01 2.7t tip with 40k on it
ECS has the 710n DV's for $45 each http://www.ecstuning.com/stage/edpd/...ategory=Intake
ah yes i forgot about the air filter ... be weary of an oil filter though because the oils get on the MAF i had to clean my MAF about a week after i installed my awe s-flo intake because of the oil from the filter
mitch's sline
B7 Models
Oct 4, 2008 07:57 PM
s4noob
9
Jun 24, 2008 02:41 PM
audiondubs25
Jun 1, 2008 03:14 PM
dr_zoidberg
Nov 4, 2007 03:27 PM
