Clean your headlights?
Old Jul 31, 2008 | 05:38 PM
makav3li's Avatar
Default Clean your headlights?
My headlights are pretty grimy and I want to make them as clear as possible. I tried using rubbing alchohol on them and right when I put it on and wipe it off it looks awesome but then goes right back to grimy, and I realized its the film that the alchohol leaves behind. Then I tried just water, didn't work, and tried armorall wipes and that didn't do much either.
any siggestions to get them clear?
Old Aug 1, 2008 | 01:55 AM
oc_audica's Avatar
Default RE: Clean your headlights?
theres a sand paper method but i tried searching and couldn't find it
Old Aug 2, 2008 | 01:29 PM
afstud6900's Avatar
Banned
use a really high count sand paper and let it set it water for like 10 minutes then go after the headlight lense with it.. i did this and then i buffed it really good afterwords. and it was much better.
Old Aug 2, 2008 | 03:12 PM
alexfunari's Avatar
rub on brasso than use a paper towel to "buff" it off, works just like sand paper, basically strips a layer from the top "the yellow junk". It really works, and its instant, I've done it a million times, get brasso at home depot. So people say mothers brass polish is better, but dude its the same stuff.
Old Aug 2, 2008 | 06:25 PM
weed4life's Avatar
For sand paper try the a HIGH GRIT paper like a 1000 grit or higher rub and wipe away. I treat all plastics in my car with Plexus then I always add a layer of wax on top for added protection. and remember NEVER spread polish or sand paper in 2 diff directions. GO in one direction (left to right) or (up to down)....same applies with applying and removing waxes polishes. NEVER use a circular motion when doing it by hand.
PS if you use sandpaper MAKE SURE you do it while the headlight is WET. Do not do it to a dry headlight, then when done rinse off and admire your new lights.
Old Aug 2, 2008 | 08:25 PM
oc_audica's Avatar
Headlamp Reconditioning Process
http://www.audiworld.com/tech/ext.html
Old Aug 2, 2008 | 08:58 PM
makav3li's Avatar
sweet deal I think im gunna do that tomarrow sometime
PSULion21
Mar 18, 2012 11:28 PM
Tourbo24
Mar 28, 2010 02:43 AM
bosslady
Apr 10, 2009 11:04 AM
CleanAudiGuy
Dec 29, 2008 04:09 PM
mschwister12
Feb 4, 2008 11:40 PM
