Clicking noise from front end
Old Sep 15, 2008 | 08:52 PM
Bill in NJ's Avatar
Default Clicking noise from front end
Hello, I just purchased an used '06 A6 Avant quattro (42K miles) from a local dealer, and have a question for this group. When turning, both right and left, at any speed, I hear a distinct clicking sound from the front end when the wheel is turned. No noise in a straight line. Any thoughts, I assume this is not normal. Would like to get it corrected while still under warranty assuming it is an issue.
Also, I have noticed the windshield wipers when off are parked on the lower part of the windshield, clearly visible above the hoodline. The passenger side wiper is particularly high on the windshield. Any thoughts as to what might be going on?
Thanks in advance!
Bill in NJ
Old Sep 15, 2008 | 08:56 PM
beefski's Avatar
the clicking is most likely the cv joints. check the rubber boots for tears.
Old Sep 15, 2008 | 09:27 PM
Bad Justin's Avatar
Thanks in advance!
Bill in NJ
it is your axle ..... and the fact that it does it on both left and right turns is an indication that both the inner and outer bearings are shot. I just did the from passenger side in my 95A6q , 200.00 installed at a local euro shop. Get it fixed man because it they blow on the road you're dead in the water. As far as for your wipers.... most likely just moved on the peg a little bit. If you live in a snowy climate its a classic after effect of not properly cleaning off the windshield with snow and ice and letting the wipers do the work.
DSMKiller
Oct 8, 2022 05:55 PM
Cioffie
Aug 21, 2011 03:34 PM
SuperSage
Jul 19, 2011 04:28 PM
eurostyleb
Jun 19, 2008 01:10 PM
Dunzie182
May 19, 2006 10:34 PM
